Site down from 1015 today EDIT: back up, all done
Started by Slim, August 29, 2025, 09:19:21 AM
Since this update I regularly am left 'hanging' and I need to re enter the BTW address to get to the page. This is on 3 different devices.
Quote from: Thenop on August 30, 2025, 11:00:02 AMSince this update I regularly am left 'hanging' and I need to re enter the BTW address to get to the page. This is on 3 different devices.
Please make sure you're using the https:// address (although you should be redirected automatically anyway). I haven't seen a similar problem and if entering the address manually works, it sounds like a problem at your end to be fair - a router reboot might help.
As it happens - this time around there were no packages to update, and nothing changed except that a reboot occurred (apart from the snapshot).
The last time that an update installed new packages was 5th Aug:
root@ip-172-26-3-246:/home/ubuntu# grep upgrade /var/log/dpkg.log |tail -20
2025-08-05 06:19:10 upgrade python3-problem-report:all 2.20.11-0ubuntu27.30 2.20.11-0ubuntu27.31
2025-08-05 06:19:15 upgrade python3-apport:all 2.20.11-0ubuntu27.30 2.20.11-0ubuntu27.31
2025-08-05 06:19:19 upgrade apport:all 2.20.11-0ubuntu27.30 2.20.11-0ubuntu27.31
Looks like these were unattended security upgrades initiated by the host.
root@ip-172-26-3-246:/home/ubuntu# cat /var/log/apt/history.log
Start-Date: 2025-08-05  06:19:10
Commandline: /usr/bin/unattended-upgrade
Upgrade: python3-problem-report:amd64 (2.20.11-0ubuntu27.30, 2.20.11-0ubuntu27.31)
End-Date: 2025-08-05  06:19:11
Start-Date: 2025-08-05  06:19:14
Upgrade: python3-apport:amd64 (2.20.11-0ubuntu27.30, 2.20.11-0ubuntu27.31)
End-Date: 2025-08-05  06:19:15
Start-Date: 2025-08-05  06:19:19
Upgrade: apport:amd64 (2.20.11-0ubuntu27.30, 2.20.11-0ubuntu27.31)
End-Date: 2025-08-05  06:19:22
Start-Date: 2025-08-29  09:15:23
End-Date: 2025-08-29  09:15:23
Can't see a problem at the server end and I've tried a different browser and my phone - looks ok.
https://betweenthewheels.net
Did this go away Nop?
Quote from: Slim on September 02, 2025, 11:29:35 PM
Yes thank you.
It did, logging out and in, resetting router, things like that.
