Upcoming Wordle Competitions
Started by Slim, March 04, 2025, 11:24:02 AM
The pressure is killing me guys.
I'm in, likely as an also-ran, but we'll see how it goes. :)
EDIT:  Shit, I didn't realise it's been about a year since I won one of these competitions. Tempus fugit..!  Even more mind-blowing is that I'm the defending Easter champion..!
OK thanks everyone, so the competition will start on March 27th with Wordle 1742 and conclude on April 5th with Wordle 1751.
I have the following entrants:
Dom
Matt
Nop
Picnic
but happy to add more.
As usual:
  • If you miss a day no problem, just use https://wordlearchive.com/ or a similar service when you can and submit retrospectively.
  • The Reg Wordle Scoring SystemTM will be used: 0 points if you fail, 1 if you get it in 6, 2 if you get it in 5 - and so on.
  • An online spreadsheet will record the number of goes per day per contestant, do the maths and display a league table.
I'm aware that I did make an error with the scoring last time. The spreadsheet shows the number of goes each entrant takes for each day so please check that if you have time. The formula is definitely correct so no need to check the calculated score.
Good luck everyone.
We doing a last day double points?
I thought not this time (myself) but I would be happy to follow the consensus view. I'll start a vote thread (why not).
So as discussed in the poll thread we are doing double points for Wordle 1751. The league table spreadsheet is here:
https://docs.google.com/spreadsheets/d/17g_Ebzps0uwLIcqDnv29xCs9BFwdXCXMROmxSDwsFrM/edit?usp=sharing
I'll put it in my sig tomorrow, will update it as and when I can.
Right after the first two rounds the table looks like this:
wtable260328.pngHighslide Image Viewer
Pretty sure I've entered the data correctly but I would encourage players to cast an occasional eye over it to ensure that the numbers of goes recorded match your actual performance from time to time. Many thanks! Live table (or as live as I can make it) in my sig.
Can we stop the competition now pls😀
You've got this Fishy. Hang in there.
With three rounds to go, the table looks like this (hopefully, please do check your numbers of goes for each round)
wtable260402.pngHighslide Image Viewer
Quote from: Slim on March 28, 2026, 07:45:29 PMYou've got this Fishy. Hang in there.
No Noppers has it...I will crumble
Right so with the final results in, the final table looks like this:
wtableeast26.pngHighslide Image Viewer
Congrats Nop! The Easter '26 Champion.
It was pretty close, bravo to Fishy for a strong second place. And as always, thanks to everyone for taking part.
